My washing machine drain water is backing up and from the past it was a clogged sewer line just past the check valve. But while investigating the clog, I notice the piping (following the washing machine's rubber hose) is corroding and will need replacement.
I'm a basic DIYer and it's not easy to accurately size the pipes (measured circumference of larger end was ~4.25" - it's reinstalled now so I can't measure diameter), but it's obviously a smaller pipe coupled to a larger pipe which then goes into the check valve -> sewer line. My question is - is there something more modern from like a Home Depot to replace this whole connection with or am I looking at doing a coupling still? Or even a check valve specifically for washing machine lines into sewer line...
6 pics below:
6 pics below:
