juniorplumber
Plumber put it in for a in floor heat loop and domestic use( which is minimal). there is no check valve in the cold water line so when the colder water gets used substantially(going to a cow waterer) the hot back flushes down the cold water line and. I also read in manual if you put in a check valve in cold supply you then need to install an expansion tank or a pressure relief valve on the cold supply. My system has no check valve and has both an expansion tank and a pressure relif valve which are installed on the out going hot water line. Why does it have to be on the cold line ? Without a check valve I shouldn't have needed either of those items. I also had a another couple gas appliances installed and both gas lines do not have drip legs. Am I out to lunch ?Maybe I just shouldn't read the manuals.
