I understand the need for venting as well as the distance tables by pipe size. I guess I am trying to understand the physics behind these images that are consistently depicted this way. At a certain slope, you can only have the vent so far from the trap so air can get back there to avoid a syphon; this makes sense. What doesn't make sense to me in the images is why does the water level rise like a wave the further down the pipe it goes? If it was 1" right after the trap and it flowed downhill wouldn't it still be 1" at the end of the pipe as it enters the main stack?
I am wondering is it due to the fact there is pressure building up as the water slug pushes air out of the pipe? More specifically, as the water starts to flow it pushes the air out and since its not open air at the end, there is some pressure build up, which slows the water enough to make it rise?
I often like to understand the why, as opposed to just knowing what is allowed and isn't. Thanks in advance
