D dgerhard New Member Joined Feb 7, 2018 Messages 2 Reaction score 0 Location , Feb 7, 2018 #1 Is this something the average Joe can replace? I accidentally broke the handle off not but turning it but getting caught on something. All the fittings seem to be threaded up to the the valve. Thanks
G Geofd Moderator Staff member Professional Supporting Member Joined Jan 20, 2018 Messages 5,337 Reaction score 1,268 Location Boston, Massachusetts Feb 7, 2018 #2 the valve is no good tha valve stem is broken you should be able to remove that one and install a new one
D dgerhard New Member Joined Feb 7, 2018 Messages 2 Reaction score 0 Location , Feb 7, 2018 #3 thanks, I assume that's a union closest to the wall. loosen the union and unthread the valve, reverse procedure to assemble?
G Geofd Moderator Staff member Professional Supporting Member Joined Jan 20, 2018 Messages 5,337 Reaction score 1,268 Location Boston, Massachusetts Feb 8, 2018 #4 that's right......easy just use 2 pliers or adjustable wrenches and put rector seal or Teflon paste on the face of the union
