cae0008
Needing help sizing my underground water line from my well head to my house and barn. My well is 320’ deep with static water level at 100’. Driller recommended setting my submersible pump at 220’. From the well, my barn is 400’ and will have a tee at about 200’ to my house that will be approximately 100’ from the tee. The house will be 4 bed x 4 bath, typical appliances, with lawn irrigation. My barn will not need near the volume of water as the house, just enough for my RV. My question is what size water line should I install? 1”, 1.25”, 1.5” etc? My well pump will like be the Grundfos SQE pump with VFD constant pressure controller. If the drop pipe to submersible pump is either 1” or 1.25”, is there any point in having a larger underground water line? Ive tried researching the science behind all of this but my brain can’t think that deeply so any help would be greatly appreciated. The price between 1.25” PVC and 1.5” is very close so is it worth installing a 1.5” line or will that be unnecessary? Would it be wise to reduce the pipe size from the “tee” to my barn or just keep all of the piping in the system the same size?
Thank You All and please let me know if you need additional information.
