para1
it's no different than working in a 3 foot deep trench.
Ha! I didn't catch the "Another Plumber" reference when I wrote that. So, dare I ask how much you'd charge for a service call from San Diego to Memphis?!?!
Seriously, there was another detail I failed to mention... When he ran the camera through the tub overflow, the pipe was very loose. You could move it from side-to-side and forward/backward. The plumbers said they probably never came back and filled "the box" with concrete after the slab was poured. Apparently that's pretty common.
The drain-end of the tub backs up to an interior wall (toilet area) so it would be pretty easy for me to open up the sheetrock and have a look from the back-side. I suppose I could do that and repeat my static pressure test while it's open to see if I can see any water escaping.
Do you think it's worthwhile for me to do that, or just wait and put my trust in "another plumber"?
Thanks again for all the comments. If nothing else, I'm learning a lot.
Steve
You can't identify such leaks by own you need professional Slab Leak Detection experts to identify it.So whenever there is leak , broken tile or slab always hire a professional to repair those broken slabs.Under slab plumbing leaks may be present for many years before they become evident. Since the sewer system is draining waste water and sewage there is no increase in water usage to alert the home or property owner.
