Under sink water heater
Chattrat
Jan 25, 2025
Chattanooga
I installed a 2.5 gallon 120volt water heater under my kitchen sink to give me quicker warm/hot water until the water from the main water reaches the kit faucet (approx 40 feet). I am using it "in line" with main water heater. All the original plumbing piping (including the feed to the kitchen sink) runs in the slab from garage to user locations. All my connections to hook up the 2.5 tank under the sink is regular flexible sink and visible for inspection for leaks.
The input of the 2.5 tank (blue) which normally would be feeding cold water is now fed gradually cold to warm to hot water from my main water heater. It runs through the inline pressure relief valve. I will set the temp for this 2.5 tank at a warm setting not real hot. As stated in another past discussion regarding the same type of installation, I am expecting the thermostat in the 2.5 gallon tank to cut off once the hotter temp water from the (garage located) main water heater reaches a higher temp. Will the inline pressure gauge with a red release handle function OK with this setup?
I plan on using a Wi Fi plug receptacle module on a timer to limit the heating to expected usage times. Any feedback for possible problems appreciated.
What do you mean by an "inline pressure relief valve"? Are you talking about the T&P valve on the water heater tank?
What is an "inline pressure gauge with a red release handle"?
I mispoke it is a T&P valve it screws on to the input nipple (blue) on the top of the unit as per instructions from the water heater manufacturer info with tank. It has a red handle that you pull to release ?pressure?. Sorry about the confusion I am not a plumber and some of my terminology may not be correct.
OP, a tank water heater will always need a pressure relief valve piped to the outdoors.
this unit has a short flexible (2ft) plastic drain tubing for the T&P valve.
You need to show a picture of your water heater. There should be three connections to the tank. One is for the cold water inlet, one is for the hot water outlet, and one if for the T&P valve. You mention that the T&P valve is to be screwed to the inlet nipple (blue). I think you are mistaken or are reading the instructions incorrectly. Again, a picture would be most helpful.
Your description about connecting the hot water line from your main water heater to the cold water inlet of the 2.5-gallon water heater, and the outlet of your 2.5-gallon water heater going to the hot water faucet connection is correct. As is setting the temperature of your 2.5-gallon water heater lower than your main water heater. The hot water from your main water heater will satisfy the thermostat of the 2.5-gallon water heater and it will not fire as long as hot water is being used.
Depending on the code where you live and the location of your water heater, the discharge line from the T&P valve needs to be routed to the outside or at least to a safe place should the T&P valve open. It cannot be reduced in size either.
This picture is before I removed the in line fitting with the red handle on the left side (red side nipple output) . There are no other connections to the tank. Based on a comment I was told to instead put the T&P valve on the input (blue side) nipple. This installation is under island sink. House is on slab. All pipe is in slab to user locations. If needed I can get creative and add a larger drain container. I am holding off on re installing the T & P valve based on feedback just for a short time.
Thanks for helping.
Thanks for helping.
You need to put that safety valve on the cold side according to the directions.
FYI the plumbing codes are designed for public safety.
That little PRV device is no -doubt not a tested/code-approved pressure relief device.
When this little unit fails, you could consider a Grundfos bridge mixer at the sink and pump at your water heater or the many brands like Laing that have the pump under the sink. 1737875942462.png
I received a follow up with the manufacturer. My set up is Good. The pressure relief valve is set for 108 from the factory. They are confident in the performance of the tank and this pressure relief valve.
I am also going to use a Wi Fi receptacle module to plug into to set typical user times. That way I'm not heating water with this unit 24 a days, saving power cost and hopefully extending the life of this small water hearer.
So I'm all set. Thanks all for trying help.
Just curious, but is that unit UL approved?
I was curious as well, and I found a U-Tube video about this unit. Here is a screen shot of the side of the unit. It shows no UL listing sticker. Also, note the "Rated frequency" of 50Hz.
The design frequencies are often listed as 50Hz/60Hz for universal items. That may not be a huge problem with this unit, but that coupled with the missing UL listing would leave me very uneasy. I think I would have spent another $100 and purchased a similar BOSCH unit. It's made in the USA, UL listed and has the standard P&T valve.
Chattrat, I'm not trying to scare you or be mean here, but you may want to rethink your installation. You said you have received communications from the manufacturer. Maybe at least contact the manufacturer again and if the nameplate on your unit does show only 50 Hz, ask them to provide written verification that you installing this on a 60Hz supply is acceptable and still covered by all warranties. That won't mean ANYTHING at all should something go wrong, and will not help in any lawsuit, but might make you feel better.
