I am working on finishing my basement and I have a new ejector pit and pump I am installing. I hired a plumber, but he did half the job and vanished. Seems like I can finish myself though.
I am at the point where I'm going to make the connections from the actual ejector pump and tie it into the existing drain lines in the house. My installation is in the basement, and I'll connect the 2" discharge straight up to an existing drain line. I'll have to check, but I think it's a 3 or 4" line in the ceiling of the basement.
Anyhoo. The plumber that vanished on me mentioned something about putting an upside down p trap at the point where the ejector pump discharge connects to the existing drain line in the house. Is anyone familiar with this? Can you explain it further or maybe point me to a couple photos or anything?
Thanks!
Chris
PS - I also have a check valve to install in the discharge pipe on the way up to the existing drain line. Are there any recommendations about where to install the check valve? High, low, in the middle, doesn't matter?
Thanks!
Chris
