tub drain replacement
Jan 8, 2025
Ontario, Canada
I'm replacing the tub drain part as shown in photo #1. The old part was broken and I had to destroy it for removal so I can't use it as a decent reference for a new part. The problem I'm having is that the mating female threaded part below the tub is smaller or has a different thread pitch than any of the drain parts I have on hand or have found in stores. Based on the attached photo #2, it looks to me like the original plumber installed a smaller diameter ABS fitting into the pipe below - a bushing, an adapter - what's the proper name for that part? I don't know if that part is threaded in or glued in. I'm wondering if that part can be removed with some careful dremel or chisel work, and that would then reveal either larger diameter threads or an ABS inner surface I could clean up for glueing in a larger diameter ABS bushing/adapter that is the correct size for my new strainer part.
    1.1 MB
    1.1 MB
Unfortunately, no access under/behind, so no, can't easily change the whole assembly or would gladly do so. Yes, I thought the sizing should be standard but none of the standard parts I've tried have fit. I've tried two standard Moen parts that I found at local stores and they seem to be the right diameter but they don't thread into the female part so I believe the thread pitch is different. A Moen M8649 is the latest part I've tried.
Thanks for the tips. This is like trying to find the pot of gold at the end of the rainbow. I did a google search for "AB&A 1658CP" and found this post of someone in the exact same situation several years ago who never found a solution:
And here's another similar tale:
https://www.plbg.com/forum/read.php?1,382993
It is nonsense like this that makes me curse the plumbing industry.
I give up. I'm going in through the closet wall behind the tub and I'll replace the entire drain and overflow assembly. When I said "no access from behind" in my earlier post, I meant without emptying a closet and going through the drywall, which is what I'm doing now.
