Betweenmatt
Hey! I've recently moved into this mobile home, and in the home is a bathroom that has had all its utilities removed a while before we moved in. Now I am trying to tap into the water supply that used to be for the sink, and I'm pretty much clueless lol. I've attached a couple images to show you the tubing and the connectors on the ends of them. I know one is hot water and one is cold, I only need the cold. Is there a connector I can get at home depot that I can just screw on to get to the water?
Fyi: I'm turning the bathroom into a washout room for screen printing, so the water will be to source a pressure washer.
Thank you for your help!
