Brand new custom home with new lochinvar 80 gallon boiler specked for my size home. Trying to troubleshoot not enough hot water by doing some tests to see if there is a crossover issue. I'll skip everything the plumber has tried so far for now. One thing he still just won't take the time to do is test for a crossover problem, so I took it upon my self to try and I'm not sure if my findings mean anything.
I turned off the hot water main line so it won't flow into the house. Turned off the recirculation valves and pump. I opened up hot water faucets from basement to top until no more water came out. Now to my observation that I'm not sure if it is weird or not. I tested the cold faucets. Kitchen/sink etc all run the cold while no hot. BUT, 3 tubs out of 2 ran super cold water, the other 2 a trickle of warm water (but it could be warm from sitting in the pipes). The master shower (two sided controls) both ran cold. One of the tubs that ran cold water has a stand alone shower right next to it and would not run cold water, just a trickle and it was warm.
Are these all determined by the cartridge valves? As in, would some prevent the cold water from coming out? Again, the cold water doesn't come out of these if I turn off the hot water to the house.
Also, the home is on a recirculation system, so I don't know if it's an issue that sink faucets start room temperature, almost warm and 20 seconds until ice cold. And the toilet tanks fill the tank with warm water in basement and main floor bathroom (closest to boiler).
Any input would be greatly appreciated, I'm about to pull my hair out. Plumber wants to replace the cartridge valves in master tub and a sink in the master but I don't think that will fix it. And he just won't take the time to test for any crossover issues.
Thanks!
Thanks!
