Bortso
I'll try to make this short. Our toilet got clogged a few days ago. No massive amounts of toliet paper was involved. I wasn't part of the initial un-clog attempt, so I don't know what exactly went down there, but here is our problem now.
- The water level is down to just a few inches
- The toilet will flush and drain slowly until it reaches that couple of inches (takes about 10 seconds), but the water level normally sits higher than that
- We tried plunging like mad using a non-bulb plunger. When I do that, its sounds relatively clear. I can hear air going in and out
- We tried an auger/snake. I've never used one before, but I stuck it in pretty far in there and felt nothing. Nothing came out either.
I'm hoping someone with more knowledge than I can help. Thank you in advance!
