bknifefight
Hello everyone. Thank you in advance for any help you may provide me. I have no plumbing experience and would like some advice from more knowledgeable people.
My toilet is having problems. It is clogged and I have determined that there is nothing in the toilet causing the clog. When the toilet was pulled, I was able to dump about 15 gallons of water (quickly) down the pipe below with no backing up issue. When the toilet is attached and flushed, it does not flush.
Our system has two air admittance valves (AAV) on it, one for the toilet, one for a sink. Upon removing the toilet AAV, it flushes great. I have tried replacing the AAV with a new, working one and it did not fix the issue. (we know it works because it was from my dad's system and works properly there)
My thought it that I should vent the toilet line outside, which is what I believe it should be to be up to code. My wife feels like there is a greater problem at play here and we should have the line snaked by a professional.
I guess my question is, if the AAV worked for so many years (the entire time we've lived there and however long the previous owners lived there after redoing the bathroom), is the venting the real issue here? Could something else cause issues that would require more air to be sucked in, which the AAV cannot provide?
Thank you all for any help or information you can provide.
