RobZ
I was working on my toilet replacing the flap & valve assembly. When replacing the flap assembly, it required for the tank to be removed from the bowl. Then when a placed the tank back to the bowl, I believe that I may have cracked something either the tank or the bowl by over tighting one of the three bolts. When I pour water in the tank water leaks through one of the bolts.
The tank is empty and when looking for a crack I don't see any cracks. I replaced the bolts and the seal, but the water keeps leaking. The tank starts leaking as soon as I pour water into the tank, but NOT by flushing the water. Tightening further the bolt does not help.
1. Are cracks visible?
2. How do I determine where the crack is, if any?
3. Is it time for me to call a plumber to replace the tank?
4. How much of a bill should I expect from a plumber for replacing the tank?
Thanks!
Thanks!
