^ Yes. make sure you prime and Glue Both the hub And the pipe ( dont be afraid of the glue on this one also ) and assemble the joint and twist and hold minding that the Toilet bolt tabs on the ring end up in the right position when finished and make sure you hold the joint as it will try to press itself apart... hold for...... 48 minutes..
Just kidding... About 30 seconds should do.
