akiceman
I purchased an American Standard Champion toilet a couple of months ago and about 2 weeks ago I noticed water coming out from under the toilet base. I checked all the bolts for the tank and checked to make sure there wasn't a cracked tank leaking water down on the base....nothing leaking that I could find. So the only conclusion I could think of is the wax ring. I removed the toilet and put a silicone extra deep ring on and after I finished I felt that I had solved the problem....NOPE! A couple of days later there is water coming out again! Ok so I tell myself I will do it again only this time I will put an extra thick way ring on. I did and paid very close attention to how I put the toilet down on the ring so I would be sure that I did it correctly....got done and was pretty happy with myself...again...but only 5 hours later I once again have water coming out from under the damn thing! It's important to note here that when I clean the water up with a paper towel or toilet paper the water I soak up is clean not dirty! Could the leak be from a crack in the base that I can't see? Has anyone run into this before? HELP!
