Hello, DIY'er here....
I noticed a leak in the basement, pulled the insulation back and saw the hole around my toilet waste pvc pipe was wet. I figured the wax ring needed to be replaced so I pulled the toilet and noticed my flange was actually two stacked flanges. The first (bottom flange) seems to be pvc cemented to the drain pipe and the toilet bolt slots are broken. The second flange is just seating on top, maybe to make the flange level with the subflooring. I also noticed the flange is about 1/8 - 1/4" lower on one side than the other.
Any recommendations on how to fix this?
Thanks
Thanks
