LearningToBeHandy
This debate comes up for me occasionally in maintaining a home and a few rentals.
When I'm replacing a compression based shutoff sillcock with a compression ball valve, is it ok to use the old compression nut & ferrule already in place?
This compares favorably from a time stand point vs using the fancy puller tool or the "I bet I can cut it just enough to pry it off" pray and hope method. The puller tool I thought would be a good send but that's kinda a pain too and scrapes the compresses ferrule across the length of the copper. That does clean the copper but I'm always a little apprehensive about what it might have done to the diameter too.
I saw a handyman reuse just the old compression nut with ferrule in place and that seems to have worked but then I wonder about tolerances and fit and all that. What does everyone else do, both professionally and practically?
