Hi all,
Have an issue: have some water filter housings that have (unless memory fails me) 1 1/2" straight female threads cut into what I believe is polyamide and I'm using brass reducers to connect copper pipe w/compression fittings.
The issue is the small leaks/sweating between the filter housing and the brass reducer. WP is max 4 bar, potable water.
So far I've been using Loctite 55 to seal any other metal to-metal straight threads with decent success, but not with these filter housings. Wound the Loctite 55 cord as many times as recommended, in the recommended pattern, still leaks. Tried other patterns - including "filling" the threads first, still miniscule leaks. First time I used Loctite 55 what started as leaks with a couple of drops per hour developed to maybe 100-200 drops per hour in a year's time, I assume the water "washed out" the compound out of the sealing cord. Tried PTFE tape - no good.
I am guessing the issue may be too loose tolerances and the fact that the compound in Loctite 55 is not formulated to harden - as opposed to other products that would.
Would be thankful for any tips on how to solve this and what to use.
