Thread engagement
Dexter
Dec 13, 2016
Hi all, new to the forum. I need to install a bunch of steel reducing hex bushings into 1" cast fittings and was curious on how far the pro's crank them in. I realize bushings are frowned upon and often unacceptable, but I am clear to use them in this instance. A co-worker told me they must by tightened until all the threads are buried and the face touches the fitting it goes into. Seems off to me, but is he right? If so, is there documentation to back it up? Thanks in advance for your inputs
They would not pass code here if it is for gas.
Well these are 1" npt, and research Ive done tells me that maximum engagement should be 6.5 threads max. I've seen plenty of fittings get busted from over tightening, as you say. I've tried explaining this, and asked what literature he saw that stated bushings need to be bottomed out, and he told me to 'look it up'. I've tried to find it and cannot! lol
