The 2 gallon tank on my shallow well pump needs replacement, but?
Qmavam
Jul 18, 2023
24
9
USA
I see there are 2 gallon expansion tanks and the there are 2 gallon tanks for pumps.
What is the difference?
Can I use an expansion tank as a storage tank on my pump?
Not effectively, there is a bladder with air that limits capacity to maybe 30-40 percent. If storage is needed a cistern or holding tank is best.
Hmm, that's not it, most Pump storage tanks have bladders in them now a days, just as the expansion tanks.
Maybe pay attention to what was replied to. I said nothing about expansion vs pressure tanks. It was regarding using an expansion tank for storage....
A 2-gallon tank on a pump is not a storage tank by any means. That size tank is solely to allow the pump switch to operate between the set pressures like 40 to 60 psi. I wouldn't even call a 20-gallon tank on a well pump a "storage tank". As GReynoldsd929 said, if you need storage, you need a cistern or holding tank.
And a better control system for well pumps is the Cycle Stop Valve instead of the standard on-off pressure switch. That system allows a smaller tank and provides a pretty much constant pressure to you house much like city water provides. It also increases the life of your well pump and saves energy to boot. Valveman on this forum is best to answer your question after you describe your wants and needs clear;y.
OK, the two gallon tank (with a bladder) I have used for the last 27 years, (I think this is the second one)
is on a pump used to water the garden and keep the greenhouse warm during a freeze. It's main purpose is to keep the pump from cycling.
So, as I see, it a water heater expansion tank is a tank with a bladder, A pre-charged tank for a pump is a tank with a bladder. I want to understand what is different and why I can't use the cheaper expansion tank on my pump.
PS
It was noticed that the pump was running but not pumping any water. I removed it, checked the impeller, it was fine, I tested the pump with a 5 gallon bucket of water, pumped fine, I tested the check valve on the well, it held water. I then noted I had emptied all the water out of the pre-charged tank, but it still held water, I pushed the Schrader valve and water came out. Then I removed the Schrader valve core and it was like I had a rocket in my hand. The bladder obviously has a hole in it, but I recharged it and put the pump system back together and it works for now. But I expect I'll need a new pre-charged tank before long.
Can someone explain how the tank being waterlogged would make the pump loose it's prime? I think that is the problem, but I don't know how it is..
I have not researched the differences between a small pressure tank and a expansion tank. I doubt there is much of a difference, maybe the diaphragm is attached differently on the pressure tank but I doubt it. If it was me I would try the expansion tank and see how it works.
A water heater expansion tank is to keep the pressure in the piping from increasing as the water slowly expands as it is heated. The diaphragm of a well pump pressure tank will flex significantly more than the diaphragm of a water heater expansion tank as the pressure increases rapidly when the pump turns on. The pressure in a well pump pressure tank will vary between 40 and 60 during normal operations, while the water heater expansion tank will basically operate within a few PSI of the set point.
I would say a water heater expansion tank will function fine for a well pump, but the life expectancy might be measured in days or weeks, not years.
Thanks, I'll just splurge for the proper pre-charged tank.
Any theories on how a waterlogged tank would cause the pump to lose it's prime?
There are constant pressure valves that use small tanks for bladder tanks. I believe they’re expansion tanks…….
Technically an expansion tank and pressure tank are the same. However, many expansion tanks have a restrictive orifice stuck in the opening. Water flowing in/out of an expansion tank should be slow, so the restriction doesn't hurt. But when used as a pressure tank a large demand such as a sprinkler valve or tub fill opening can cause the pump to start before the tank has emptied because of the restriction.
Yes, a bad tank diaphragm can cause a pump to loose prime. The waterlogged tank causes the pump to cycle on/off rapidly until the overload trips. With the motor shut off there is nothing in the tank to keep the system pressurized, and loss of prime can happen.
A 2 gallon size pressure tank only holds 1/2 gallon of water. 25% water, 75% air. That means the pump cycles rapidly when using any flow rate except max flow. Cycling causes the tank diaphragm to break, then the pressure switch, check valve, and pump/motor itself are next to go. A small pressure tank is fine when used with a Cycle Stop Valve as the CSV stops the cycling. Without a CSV the larger the tank the better.
Thanks for that explanation. I don't expect to make any changes to the system, as the pump does not cycle (they way we use it) and I have got good life out of the pre-charged tanks. I will have to spend a little more and get the non water heater expansion tank.
Thanks all
I have three brands of expansion tanks in my office right now and none of them have any restriction.
I know right? I sold thousands of expansion tanks for pressure tanks. Then the last batch that came in had a restriction device. Had to send them all back. Aggg! Don't know why they fixed something that wasn't broken. :mad:
Switch brands
Switch brands
You would be surprised how many brands are made by the same manufacturer and just labeled with different names. But even with other brands to choose from I can't find a good replacement for the 10 gallon tank. So far am able to find the 4.5 gallon size that works. Just having to redo everything to make a new 10 gallon tank work. :huh::pissed::PullingHair::grrrr:
