I am thinking about purchasing a tankless water heater, possibly the Rinnai Rl94i or the Rl75i.
According to what I have read and the clearances listed in this PDF by Rinnai these are the clearances that would apply to my install.
Do these all sound correct so far? Because I am limited as to where I can place the water heater inside and considering all the clearances above, that leaves only one place that is practical for the vent to exit the house and that is about 30" from my AC condenser unit. If you look at the attached picture you can see the location is exactly where the current power shutoff for the AC condenser unit is, which I will have to move. My question is, will this be too close to the condenser? Will the condenser disturb the airflow for the vent and intake of the water heater?
Also, any opinions of those two water heater models?
Thanks
- 36" from an opening window.
- 36" above grade.
- 12" from an inside corner.
Thanks
