Nukedaddy
I was a plumber for many years but got out of that industry to fix nuclear plants. During my absence, gas tankless waterheaters finally improved to the point of popularity. I now own a Rinnai that is hung on the OUTSIDE of my house! You can imagine the shock to my poor Yankee Plumber's heart to see that! The house is 22 years old, and the Rinnai was installed before I bought the house (in Vicksburg, MS) and replaced a 50 gal propane tank.
It is and was common practice to NOT put in a main water stop valve where the service enters the house. (Down here they apparently never had to dig through a few feet of snow to find a meter stop or curb box.)
Anyway....The piping appears to be all copper, and headered for splitting off to all baths, but hidden in walls or behind tub-showers. (No access panel)
The tankless works great, although it takes a good while to get hot water to the master bath. Also, the dishwasher never seems to fill at a rate to get the tankless to turn on and provide hot for dishes.
So, two questions for you cats without a 15 year gap in your experience:
I read that there are ways to set up a circulating system using a small thermostatically controlled pump between the furthest hot and cold lines. Physics seem sound and no new piping. Does anyone have an opinion on them?
Also, the dishwasher. Has any one run into such an issue before? Is it possible to obtain a solenoid inlet valve with a faster flow rate that will cause the tankless to run? Or would I be begging for a flood? I just dont remember if dishwasher fill is determined by a time or a float switch.
Thanks,
Nukedaddy
Thanks,
Nukedaddy
