During the winter thaw and all spring, my sump pump goes off literally every 2 minutes. A drainage specialist mentioned possibly raising the pump so that the float would trigger when it was about an inch or two above the bottom of the drains leading into my pump. His theory was that water would slowly accumulate in the drains thus taking more time to trigger the float.
This seems to make sense, but by reducing the frequency of the pump going off, each discharge would add more volume of water (since much more would have accumulated in the drains). My question is, what takes more of a toll on a sump pump's longevity: going off more frequently with less water OR pumping less frequently with more water in each discharge?
Any thoughts on this would be appreciated. I just want to make sure I'm doing what's best for the longevity of the pump.
Thank you.
Thank you.
