ryanmar814
- Joined
- Oct 25, 2022
- Messages
- 5
- Reaction score
- 0
Hello,
Is it ever considered normal for a sump pump to short cycle aka going off every 10 seconds constantly?
My landlord left the sump pump unplugged after installing it himself and the basement flooded. After plugging it back in, it constantly cycles every 10 seconds without fail, 24/7. It had been short cycling for several days. He came back and unplugged it to "let it evaporate" for a week but he's plugged it back in and it went straight back to short cycling. The sprinkles are off and it has not rained or snowed. He said we should just let it constantly short cycle until water evaporates.
To me, it sounds like the pump isn't able to fully discharge the water so some falls back into the pit, thus triggering the pump to go again. I think this is a catch valve issue.
It's a 3/4 hp in what looks like a 7ft sump pit.
His initial fix was to put a rock in the bottom of the pit. That did not work.
Could someone please advise on if short cycling is ever "acceptable"? It is my understanding that this will cost quite a bit in electricity and will burn the pump motor out.
Thank you so much
Thank you so much
