I had an issue with the dishwasher waste water back flowed into the air gap on the counter top. The original drain hose had a loop before connecting to the tee.
I thought the loop might slow down the waste water discharge, so I straightened it out. This is what it looks like now:
The new problem is when I just wash dishes by hand, suds comes out of the air gap after approximately 5 minutes of washing using regular dish detergent.
So it looks like I traded one problem with another. I assume the original loop on the drain hose prevented suds from going further up to the air gap, but made the discharge less efficient. I am thinking about a couple of options:
1. Get rid of the air gap and have the dishwasher drain goes directly to the tee. The question is - Where should I connect the RO faucet drain?. Shall I try to make a high loop to prevent suds going into RO faucet?
2. Install a compact garbage disposal to act as a buffer when the dishwasher is discharging waster water. However, because I have a deep sink, I am not sure I have enough space under the sink.
3. Any suggestions from you guys.
I do have a waste basket in the sink, which I clean after every use, and I am pretty careful not letting large pieces of food waste flushing down to the drain. I haven't checked yet, but I don't feel the p-trap is clogged.
