indifferent
I have two outdoor faucets; one of which is installed after the whole house water pressure regulator. The other one is connected to the main pipe right before the water pressure regulator and this is the one that simply doesn't supply enough water to run a single rotary or oscillating sprinkler. Oddly enough, the very same hose/sprinkler combination works perfectly fine when attached to the other pressure regulated faucet. I've checked water pressure on both faucets and the pressure is slightly higher (44 psi) on the faucet which does not work, as it should be. Pressure on the other faucet is 40 psi. There are no any leaks in the house. It just doesn't make any sense that a sprinkler connected to the faucet with higher pressure will not work. See the attached image. Any suggestions?
