Hello All,
If this post is better suited to Sprinklers and Irrigation Sub please tell me. This issue is pump related albeit a sprinkler pump.
My sprinkler pump shuts off randomly. This happens on the “auto” setting, so I am by passing any timers.
Today I replaced 2 old wires on the low pressure switch. They were old and burned. The strange thing is that this had no effect on the pump. It worked intermittently before changing the wires and worked intermittently after changing the wires. I’ve attached pictures for review. The 2 wires I replaced are supposed to supply electricity to the motor (denoted by a yellow M). These wires are attached to the 2 brass screws in the middle. The 2 wires with a green check mark have power. The 2 wires with a red X do not have power. Any suggestions?
Just to clarify, the system pressure is constant at 50 psi. When the pump is working, the motor is spinning and all sprinklers are shooting water. When it shuts off the motor does not spin and there is no water coming out of the sprinkler heads.
IMG_1464.MOV31.4 MB
IMG_1464.MOV31.4 MB
