Hello everyone, I'm new here and hoping to gain a little insight from you all. We are building a new home and have a spring and creek on our property, the spring we'd like to use for water is down a STEEP and rocky bluff, about 300-400' of total run from the house. I've had a well guy out and he said using the spring would be no problem, that he could install a "lake water system" in which the pump (housed in a basin sunk into the spring area) would fill up the pressure tank then drain the remaining water back out of the supply pipe so it wouldn't require trenching down the bluff to avoid freezing- SW Missouri for climate reference.
This sounds great, but I have some concerns which he didn't seem too concerned about so I thought I'd get more opinions here.
The volume of a 1" supply pipe traveling 400' is roughly 16gal, correct? With a standard well pump wouldn't we be looking at around a minute of pumping just to get the water back up to the pressure tank each time the switch activated? Would a larger than normal pressure tank alleviate this issue? How much energy would we be wasting to pump back up the water through an empty pipe every time?
I'd much rather use the spring water than a well, it's a cheaper option and also a better quality water. We have a high sulfur content in most well water from our neighbors. I also know we'll need an extensive filter system which as already been priced in. Any input is welcome, thank you!
