YoDaPlumba
Hi everyone, this is my first time posting on the forum, and I’m looking for some advice on my basement sink pump setup.
I’m having an issue with my basement slop sink setup, which requires a sump pump due to my drainage system. Here's what I have installed:
Any advice or troubleshooting tips would be greatly appreciated.
- Pump: Little Giant WRSC-6 (1/3 HP, 2760 GPH, automatic sump pump system)
- AAV: Studor 20341 Mini-Vent Air Admittance Valve
- Check Valve: PumpSpy Silent Check Valve (1-1/2", spring-loaded flapper)
- Immediate On/Off Cycling: When water enters the drum, the pump kicks on instantly and then off right away. This rapid cycling seems bad for the motor and might burn it out.
- Poor Drainage: When I fill the sink and then try to drain it, the pump struggles, and the water drains slowly. The sink gurgles, and the check valve flap visibly stays closed while the pump is running.
