Water is leaking out of my pop up drain and I have not been able to stop it. I have purchased a new drain and new pipes, installed them, and reinforced them with plumber's putty and plumber's tape. The water is leaking from the part of the drain that touches the sink. The part with the rubber gasket and the nut. The water leak starts out slow, but eventually gets to a pace of about 3 drops per second. I have noticed that when the drain is plugged, the sink does not leak, it is only when the water is running through the drain. Hopefully someone is able to help me, thanks!
