Evan Brenner
Hi,
I'm brand new to plumbing, but have a problem I wonder if anyone could guide me on.
Basically, at the bottom of our farmhouse sink there is a hole where the water drains. It's about 1 1/2 inches in diameter. The water flows into the hole. About two inches down the hole is a little crossbar which would catch large debris (a fork, a ring, a bottlecap, food - whatever one might not want going down the drain).
The problem is, this crossbar is seated like two inches down the drain. So food builds up and I must routinely (once or twice durning after dinner dishwashing) reach in with two fingers and try and clear out food. This is super-annoying, unpleasant, and time-consuming.
I had the sink recovered a few years ago and although I don't remember exactly how the drain worked prior to the work being done, I don't remember this problem. Should/can the crossbar be put in flush with the bottom of the sink?
I unscrewed the drainpipe and took a picture under the sink in case that would help diagnosing and resolving the problem.
Thanks!
Evan
Thanks!
Evan
