Kurgen
Hey guys,
One of my upstairs showers is experiencing a low pressure situation. It is low at start and drops as the shower continues. I replaced all three valves to stop the leaks and replaced the showerhead, but it did noting to help the pressure. Pressure is good in all other baths. The house was repiped with flex hose a few years ago. The valve body and stand pipe to the showerhead are original.
Could this be a scale issue or some other blockage in the valve body? If so, will that cause the pressure drop I noted during use? My next step to solve this issue was to replace the valve body and stand pipe, but I thought I would check here first as it is my brother's house and he will be pissed if I suggest he spend the money and it does not good.
Thanks in advance.
Thanks in advance.
