Prinsens
I need to install an outdoor sillcock on a stucco wall. A 1/2 inch CPVC pipe passes through the stucco to the outside of the house about 1 foot and has been capped off.
I will need to cut off the pipe and install a sillcock. There is no play in the pipe (won't move in or out).
I am also concerned that once I install something, if I ever need to change it out later, I may break the CPVC pipe in the wall.
Is there a mount or spacer or something that I can use?
