Hi everyone,
first time here, and of course I need some help to figure out a plumbing issue.
I am converting a bath/tub enclosure to a walk-in shower type.
The rough-ins inspection has been done and all approved, but...the inspector recommended to consider changing the 1.5 inch drain pipe to a 2 inch one.
It would be really a PITA - he said I might be able to have enough flow/drainage, but might have also some slow drainage issues.
The run is properly vented btw
So, my questions are:
- can I indeed leave that existing pipe alone? the water pressure is standard, and the shower pan 3x5 feet will have the drain at the center or about 6 inches from return wall, and will be tiled with sealed stone pebbles (increased slope)
If, indeed this pipe sizing is know to cause a lot of issues with showers, I rather solve it now
- assuming that I keep the 1.5 inch drain pipe - how can and should I adapt the 2 inch drain to the 1-1/2 pipe? - yes I will install a P trap and the pipe runs parallel to return wall so needs a 90 degree elbow in the run for a center pan drain.
Thanks in advance for your help and advice
Phil
Phil
