Shower P-Trap Clocking Angle
quasiloci
Dec 28, 2017
Hello,
I am new to the forum and am hopefully not breaking any etiquette with my first post...
I am working on re-modeling our master bathroom (by name only, not by size). I would like to change from a center-drain pan to a linear drain along the shower head wall (to give more room for a small corner bench , avoid standing on the drain, and to simplify the tile pattern/cutting).
I have removed some of the sub-floor to gain access to the plumbing (and this portion of the sub-floor needs to be replaced anyway).
The only way I can think to fit the linear drain and position the linear drain outlet within a joist cavity is to get an "offset outlet" drain, and to rotate the p-trap back towards the horizontal drain pipe.
To better illustrate please see the attached image.
Is this OK? Can the P-trap be rotated at any clocking angle with respect to the horizontal drain pipe? Or is this opposite change in "flow direction" a bad idea?
Any other ideas, or should I give up and stick with the original centered drain location?
Thanks in advanced.
Cheers
Yes you can rotate into any direction you need. That is the beauty of a plastic trap over a cast iron no hub trap
Awesome! Thanks for the quick reply Mr_David!
For some reason clocking this way goes against my intuition.
quasiloci, that is a very nice drawing you submitted. What did you use to render those images?
