NikkiPlace
Dear forum,
I have this strange situation, that has been confusing two plumbers that I was consulting. I hope you can help with advice!
When I start my irrigation system, my master-bedroom shower will make a terrible grinding noise, followed by some water leaking from the shower head (see/hear in the attached video). This will last a few seconds, then fade. Except for that effect, both the shower and the irrigation system seem to work without problem.
More information:
My questions:
I’m completely confused about it and have no idea how to go about it.
Thank you for any advice or direction!
Nikki
More information:
- House water pressure is around 100 PSI.
- The shower is on the upper floor (split-level house). The house has other showers (including on the same floor and in the basement), but the aforementioned effect takes place ONLY in that one specific MBR shower.
- That shower was sometimes leaking (without noise) when toilets were flushed in the house. Plumber was called and replaced the Kohler K-GP876851 Rite-Temp Valve, and it fixed the problem with the flushing. However, a few months later when I started the irrigation system, the problem I mentioned started.
- The plumber said the new problem has nothing to do with the part that he replaced (which I find weird), and suggested it’s because of the high water pressure. He suggested installing a pressure reducer after the meter, taking the water pressure down to around 85 PSI.
- The irrigation system is automated, and has a solenoid master-valve located just below ground level. Its water supply is ¾”, right next to my water meter in the basement, approx 6 ft below ground. It has a Febco 765 Backflow Preventer before the master-valve.
- I called a second plumber who saw the leak/sound effect, said he never saw anything like that and hence preferred not to deal with it.
My questions:
- First and foremost, can I operate the irrigation system safely, or does that sound/leak indicate something bad is going on? (if so what am I risking?)
- What do you think is the root cause of the issue, and then what should be the fix?
Nikki
