luap2003
Have had this issue off and on for about 2 years now. I'm pretty sure the outer lip of the upper drain assembly isn't properly sealed to bottom of the one piece shower base. I'm assuming this is a base/pan combo? There is no access to see below the shower unit.
As you can see by pics, I would like to remove the old drain and either install new (if that can happen) or somehow remove the upper part of the drain assembly and replace a gasket or figure out how to seal the pan to the drain. Basically, per second picture, I believe the leak I have is caused by the pan dropping slightly when in the shower and close to the drain. Water seeps between the lip and the bottom of the shower base.
I caulked it several times (see pic) and it seemed to help, but problem is there yet again and I want to fix it permanently. Water is flowing under the shower base now and out of the brick on side of home...not tons of it, but enough to know probably some mold/mildew going on and some baseboard near shower is wet...
Any help/thoughts greatly appreciated! Is this a DIY project or do I need a pro?
Paul
Paul
