So the drain to my shower has been draining rather slowly since I moved in. I'm assuming that it was mainly hair that is slowing it down so I got a snake wire to try to fish the clump out of there. However there is a cap on the drain that seems to be glued down so it can't be removed without damaging the tub... getting a snake down there isn't an option.
I tried to put some Epsom salts in there to try to break things up but it only clogged it up more. I read that boiling water will dissolve epsom salts but it barely drains at this point and I'm not sure if putting hot water would help considering how slow it drains now.
Any suggestions to get the Epsom salt and hair out of the drain?
