Thanks for your reply.
So its actually the mixing valve that is leaking, that black cap between the 2 outlets.
I powered off the unit lastnight before I went to bed, and then I turned it back on when I woke up this morning.
I gave the mixing valve a little tap to secure the leak better, of which worked, only a little leak coming out after that.
However, now the boiler wont start...
I'm not sure why.
I'm fairly sure when I started the unit this morning I heard the boiler start.
Now that there is no pressure in the unit, there is no leak present. Also no hot water...
Any thoughts?
Much appreciated
