I had a small 6 gallon pressure tank in my cabin. Caused the pump to run every time any water was used, even a glass of water.
I got a new 32 gallon pressure tank to add to it. In the process of checking to see that they were both the same pressure, I realized my original tank has zero pressure. I tried using my compressor, even though I was adding 28lbs of pressure it still reads zero on the tire gauge.
Can I hook up the new tank inline even if the old tank has no pressure?
