We need to install a charcoal filter on our septic vent pipe and I'm struggling to determine where I should locate it.
The normal installation locations (on the roof, or an in-line type of filter in the attic) are problematic due to unsafe access; we have a very tall two-story house, and the attic is a truss system with blown-in insulation and minimal headspace.
Stating the obvious here, but our main vent pipe comes through interior walls before getting into the attic. Once in the attic, two smaller vent pipes (one from the second floor shower and one from the second floor laundry) tie into the main pipe before it exits the roof.
Would it be a bad idea to install the filter on only the main pipe, obviously above all the drain locations, but prior to it going into the attic and before those other smaller vents tie in to it? Would there be any back pressure issues given that the two smaller vent pipes would tie in the the main vent pipe above the filter? We'd obviously need to cut the sheetrock on an interior second floor wall, but that isn't an issue because it would be in a closet.
