Looking for some guidance on how to check if my drain field is plugged. I will try to make this as short as I can but I want to gve enough info for you guys to give me some direction.
First thing I want to say is I'm going to do as much as I can myself before paying someone to come out.
History: The house was build pre 1900's so a very old farm house. We bought this farm in 2014 and the previous owner moved to a retirement home in 1990 so the house sat empty for almost 24 years. The owners grandson inherited the property in the mid 90's and had plans to fix it up. He gutted the house of everything (all old plumbing) put in a new submersed well and had the septic tank pumped but he never moved in because he moved away for work. When we bought the farm he told us his family had owned the farm since 1936 and his grandpa and grandma lived in town and used the farm as kind of a weekend place for years. When his grandpa passed away in 1970 his grandma decided to move in full time and she had the septic system installed at that time along with some other improvements. We renovated the house and put in all new supply and drainage plumbing inside and moved in late 2014. In 2015 I had a drain issue, I ran a snake down the drain in the basement clean out and found out the old clay (I think it was clay, not hard clay pipe but a kind of soft material) had collapse. So I put in new plastic drain pipe from the house to the septic tank. We didn't have any issues until the fall of 2021 when it backed up again. Again I ran the snake down and it was not plugged so we had the septic tank pumped and this fixed the problem. When we had the tank pumped they inspected the pipes inside the tank and the inlet and outlet pipes looked good.
Present Issue: The drains are baking up again. It happened quickly without any symptoms like the year before when the tank was getting full and we had slow draining and had to plunge the toilet every few days. I figured the main drain was plugged so I ran the snake down and it goes all the way to the skeptic tank with out any resistance so no clogged pipe. Also the draining is completely stopped because the water doesn't go down at all overnight. So I'm assuming it is some kind of drain field issue, maybe it is the same kind of old clay pipe and is broken down like the inlet pipe to the tank. I have an idea of the direction of the drain field but not 100%. The other thing I don't know is what kind of drain field was installed, if it has a split box or how many legs it has. Does anyone know what was the typical drain field design used in Mid-Michigan in the early 70's? My thought is to dig down to the tank outlet pipe and start following it looking for bad pipe but I'm not sure if something else I can do to confirm the drain field is the issue. I have inspected the area that I think the drain field is located and can't find any standing water, extra green grass or other visible signs of a bad drain field I have read about. One thing that kind of puzzles me is they also built a new garage next to the drain field area in 1970 when they were doing all the other work and it has a center drain. I'm making an assumption that the garage drain is plumbed into the drain field. When I run water down that drain it doesn't back up at all.
Any thoughts on what I should do next?
Thanks in advance.
Thanks in advance.
