I'm putting in a laundry room into a guest house of mine, and currently doing the plumbing. I went 2" up to the house above grade, then transitioned over to 1.5", because of a few reasons, mostly tight space. My question is, for the sanitary tee, there isn't code requirement for height of the cleanout, correct?
Also, the sanitary tee I used might possibly be incorrect, there is no curves to the tee, all 3 sections are straight, this is incorrect?
In the photo, you'll see the cleanout with a AAV glued to it as well. I was planning on just putting both together and have it in the wall with a removable vented cover, this is fine?
Haven't glued any of that together because I'm not sure if there is a height requirement on the cleanout, so the photo is with the pipe and cleanout/AAV just pieced together.
