Replacing laundry tub faucet
Boeheckler
Nov 20, 2013
Hello,
I am trying to replace an old laundry tub faucet that is broken, and I was told unfixable by a plumber. I would guess that it is 40 or 50 years old. I have attached a photo of it to my post. I believe it is what is called a wallmount service sink faucet. With the faucet removed I have two, 1" male threaded connectors sticking out of the laundry tub that I would like to put a new faucet on. I cannot see how these 1" connectors connect to the supply lines without removing the tub which I think would be a big job, so my preference would be to connect the new faucet directly to the 1" connectors. These connectors may have been part of the old faucet, I am not sure. The 1" fittings are 8" apart at center so that looks pretty standard. I can get a Delta teck series 28T9 faucet that looks very similar for a good price online. Otherwise I have discovered that replacements are typically between $300 and $500, which I don't want to spend on an old laundry tub. The literature shows that the 28T9 comes with a 1/2" NPT male connector, though it looks like this connector can be removed back to a female nut connection right at the faucet. See link.
http://www.specselectonline.com/PDFS/DSP-28T9.pdf
My question is; can I attach the faucet directly to the 1" connectors or do I need to remove the tub and do some plumbing work so that I have a 1/2" female fitting to connect to? I am sorry if I am not using the right terminology as I am not very experienced in describing plumbing issues. If I had the new faucet in hand I could answer this myself, but I have to order it. Any advice appreciated. Thanks.
You can do both, but if you don't want to spend lots of cash for your faucet, you can attach the faucet directly to one connectors and remove the tub.
Thanks Lolipoli. I was able to remove the 1" connectors and get back to the 1/2" piping without removing the tub. I didn't think that the connectors would come off easily and I would wreck the 1/2" copper pipe, but with a torch I was able to get them off. The new faucet is installed and working. Thanks for your response.
