I need to replace pilot and tube on older water heater. The replacement pilot says it can adapt to 3/8 tubing[see pic]. My existing pilot used 1/8in. tubing with these factory ferrules press in the ends [see pic]. How do I use 3/8 tubing to new pilot assembly and get the 3/8 tube to "make up" back at the valve where existing 1/8in was connected?
I need to replace the tubing along with pilot. Those ferrule tips have come loose and are allowing leaks backside of nuts.
