Hello! So my kitchen sink pvc pipes started leaking at one of the joints. When I looked at it closer, I found that the piping was done incorrectly. So I went and redid all the piping. Everything seemed ok at first, but since I have been monitoring it, there is a slight leak where the pvc pipe connects to the metal drain. I tightened it as much as I could without the metal drain rotating. That brings me to my first question... I was told if the metal drain can rotate, that means it’s not on tight enough. I tightened it as much as I could, but it still seems to want to rotate. I tightened it with a wrench and my bare hand holding the base in place, but it still wanted to rotate. Is there something else I need to do to make it tighter?
Then to my second question. How do I stop the leak? All the piping is brand new. I did not put any sealant or washers or anything to seal that joint... do I need to? It’s possible I put a washer on there as I put one on all the other joints, but I don’t remember putting one on there and don’t want to take it all apart unless I am suppose to have one there.
