Long story short. Bought an older home (1961) and all the old shut off valves have started to leak. House is single story on a crawl space.
This is my first home and I have little plumbing experience but I've done a fair amount of research in a short amount of time. I've replaced valves and spickets before. I'm familiar with plumber's tape but I've never had to cut any metal pipes or solder. Until now.
The piping is a hodge-podge of old original galvanized, a lot of which has since been replaced w/ copper (I found the old galvanized lines in the crawl space), and some PVC as well. I intend to utilize PEX for all replacements where suitable, and I have what I think is a decent plan but I'd like to get some sort of affirmation before I make any cuts in the morning.
My urgent leaks (there are numerous other smaller issues) are in the guest bathroom and underneath the kitchen sink. In the guest bathroom, the toilet supply valve is leaking, even when turned all the way off. The valve is soldered flush w/ wall to a stub out that comes from inside the wall btw that bathroom and a bedroom closet. The pipe that leads up to this valve is 3/4 in galvanized. The line that leads to this pipe is 1/2 in copper and the two are conjoined at a brass elbow. It looks like these connections were soldered as well.
I intend to cut the galvanized pipe above this elbow using a 3/4 in pipe slice, pull the valve out of the wall so that I can (maybe?) cut it off the stub-out, and then free the old galvanized supply pipe underneath the house. I would then cut the copper pipe just upstream of the elbow, install a push-to-fit SharkBite connector, and run pex up and out the wall of the bathroom, and install the new valve to my new PEX line. Will the PEX be able to bend like I want it to, up and out of the wall enough for me to install a new toilet supply valve without any issues? Do i need some sort of support for this bend? My goal is to not have to tear into the wall in the closet behind the bathroom. Tearing into the actual bathroom wall itself would be an even larger task as it would involve busting out tiles. Is this all a waste of time? Should I just buy a torch and remove the old valve, and replace it with a new compression type ball stop valve?
I was told I don't need any kind of special tools for the push-to-fit connectors, so I intend to do the same sort of thing to my cold water kitchen sink supply line. If it were the shutoff valve that was the only issue here, it would be simple because this one is a compression fitting from copper to plastic. However UPSTREAM of the cold water shutoff valve, there is an old copper ice maker line with a valve that you cannot turn off (so we've been wasting water through this line since we moved into the home), and recently that valve itself started leaking. So I believe I'm going to have to cut the copper pipe in this case as well. Since I'm working on this line, I want to install an in-line water filter and a new ice maker valve. This issue just got upgraded to urgent yesterday so I'm not sure the best forward plan for this yet.
I also intend to add a dishwasher and a garbage disposal to our kitchen in the near future as well. Is there any work that should be done to this cold water (or under sink in general) to prep for those projects in advance? The dishwasher will be installed in an island to be built near the sink.
https://imgur.com/a/hrz4Qwq
https://imgur.com/gallery/hrz4Qwq
