sarg
Our toilet is about 40 years in service and usually functions OK.
Occasionally we need a slight - gentle plunge to assist the evacuation.
I noted a build up of a scale ... best described as what appears to be a pebble type build up directly below the tank flapper only visible when you lift the flapper and look in the cavity below with a flashlight. This build up appears to fill up about half the original volume. My concerns are build up in the internals of the toilet ... which is why I removed the water in the bowl and poured vinegar through the overflow pipe filling the bowl and letting it set for hours ..... all without much success.
Now I'm seeking a hydrocloric acid type "delimer" ... such as Rooto 3 in 1 . ( Over $60. a quart )
I'm wondering what the experts here would recommend to dissolve this build up. There are dozens of different "de-limeing" solutions with the hydrocloric acid and some must work better than others..... which may be a product of acid content percentage.
Any guidance from the experts on what works best ? ( The idea of pouring a $50+ quart of liquid down a toilet is a little disturbing. )
