refr. grade copper for ice maker?
whoru9999
May 7, 2010
5
Hello,
I am running a new line to my refrigerator for ice / water. I have some 1/4" copper tubing that is refrigeration grade. Can I use that for the run, or should I buy utility grade?
What is the difference between the 2 types?
I wouldn't. Refrigeration copper is much thinner walled. It kinks easier when you handle or bend it, is damaged easier, won't hold as much pressure, and will fail quicker.
Get some Type K or Type L copper.
The refrigeration grade coil I have is .030 nominal wall thickness, which I believe is the same as type L, isn't it?
